How do you remove dry grout on tile. We have tried everything from vinegar to tile cleaner, but nothing is working. Any suggestions?
What type of tile is it? The answer may depend on the material. – auujay Dec 27 '11 at 2:20
Have you tried acetone (nail polish remover)? – RQDQ Dec 27 '11 at 14:07
Your options at this point are scraping it off or dissolving it. My first suggestion would be contacting the tile manufacturer. They would have the best idea of what your tile can handle as far as physical abuse or acid.
Scraping
Scraping is attractive as a primary option because you can go slowly and start in a small inconspicuous area to see if it will damage the tile. There's no perfect tool for this as far as I know. I'd start with an abrasive sponge (you might get lucky), steel wool (good for streaks) and then lightly attack clumps with a razor, painter's tool or small sharp chisel. To limit damage to the tile, you want the tool to be as horizontal as you can make it and still work safely with it. You should quickly determine how much abuse your tile can handle and if a few scrapes ruins your floor. Most likely it will be a slow and painful process.
Acid
Sulfumic acid will work if the grout is not too thick, the main concern is what it will do to the tile underneath. Again, find a small spot to test first. Etching is usually caused because the tile absorbs the acid. To limit this, I would wet the tile pretty thoroughly with clean water first. Gloves, mask, and good ventilation are a must when working with the acid. If the grout is pretty thick, this may loosen it up enough that you can scrub it away with a scraping method. Follow the instructions and don't let it sit long enough that it eats through the top layer of tile.
Replacement
I wouldn't overlook replacement as a possibility, depending on how many tiles are an issue. It's entirely possible you will damage the tile trying to remove the grout anyway. I'm assuming you did the tile work (or you should be calling the contractor to fix this), so you should be able to replace a tile, just break it, scrape up the surrounding grout and install a new one. If it's old work (and you can find tile that matches), it might be worth a few calls to find what a tile mechanic might charge for a small job.
Is it on glazed tile, or something like unglazed spanish tiles? If they are glazed, I would try a razor blade scraper or a wallpaper scraper. Try wetting it first. I have heard of people using acid, but I see some forums where people say never to use it because it can etch the tile. If its only been a couple of days it should come off glazed tile. You could also post a picture. Good luck,
Brian
My wife dropped a full bottle of Balsamic vinegar on our kitchen floor. It immediately attacked the white tile grout and by the time the mess was cleaned up most of the tile grout was gone. The Balsamic vinegar was a blackish colour and the white tiles were not affected at all.
-1 cool story, bro.... Can you adjust your answer to more specifically address the question? – Matthew Feb 5 '13 at 5:27
Tried the balsamic vinegar, let it soak for about five minutes and used a scrubber brush then wiped clean. Works well but had to do about four times. Much better though than the nylon brush which in all fairness we could not get the right one. The one we got took ages and being such small tiles would have taken forever. Definately the vinegar is the way to go. Don't know the finish yet once polished so will keep you posted. – user19992 Feb 19 '14 at 11:04
protected by Community Aug 7 '14 at 1:21
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
