Tell me more ×
I know this sounds like a silly question and it may be closed before it may get a single answer but there is something strange in my house which beeps infrequently. I tried to troubleshoot the sound but no luck. I thought may be its coming from the living room but there is nothing special in the living room which may make a beep sound.
Can someone point me what should i look for to figure out what is making this sound?
Sure it's not one of these? – Doresoom Dec 23 '11 at 20:38
@Doresoom : I just lost my 30 minutes bcz of your comment. ;-) – Asdfg Dec 23 '11 at 21:08
Did you find out what it was?? – Torben Gundtofte-Bruun Jan 18 '12 at 16:01
i changed my sump pump's battery but still something is beeping. still working on it. – Asdfg Jan 19 '12 at 4:27
finally spent 4 hours in the basement today and found that fios battery is down. – Asdfg Jan 23 '12 at 0:54
up vote 2 down vote accepted
Fios battery backup? Those can beep.
Finally i figured it out today. – Asdfg Jan 23 '12 at 0:54
Random theories:
  • smoke alarm
  • kids toy
  • a robot
  • cell phone
  • handheld video game
  • a bomb
11
usually a smoke alarm or carbon monoxide alarm with a low battery. The occasional beep is the signal that the battery is getting low. They can be frustrating to locate as for some reason the high pitch beep is hard to narrow down to a single room. I usually close all the doors to rooms to help eliminate areas. – qes Dec 25 '11 at 4:18
Most likely a smoke detector or CO detector with a dying battery.
i know the sound of smoke detector which is pretty loud. This beep is not that loud and if i am watching TV, i barely hear it. I dont think i have CO detectors in my house. – Asdfg Dec 23 '11 at 19:54
I have also heard some cordless phone handsets make a beep when their battery is almost dead. Check the couch cushions. – DaveNay Dec 23 '11 at 19:55
No cordless phones in the house. – Asdfg Dec 23 '11 at 19:56
The dying battery sound of a smoke alarm or CO detector is not going to be as loud as when it's actually warning you. Check them. – The Evil Greebo Dec 24 '11 at 17:12
it looks it was furnace thermostat filter is beeping. I have turned it off and cleaned the filter. If it still beeps, it must be Sumpump battery. Thanks for helping me to narrow it down. – Asdfg Dec 25 '11 at 19:20
show 10 more comments
On top of what other people have said:
  • Fridge (door open, temp low)
  • Computer
  • Thermostat (filter reminder)
  • Alarm clock (low battery)
Or maybe it's not a beep but rather a squeak (furnace fan, fridge compressor, door opening/closing, window, etc.)
I'd say it's a fire or smoke alarm. Is it a short chirp every couple of minutes. If its not somewhere obvious then it might be a bit difficult to track down, human ears are very bad at locating these high frequencies. You could try using you computer to measure the volume at various points in the room. Sounds elaborate but it might be the only way to track it down.
sometimes it beeps once in a couple of hours and sometimes once in an hour. It doesnt beep very frequently. I tried to note the timing and found it at least beeps once in two hours. – Asdfg Dec 23 '11 at 20:02
Is it just a single beep or a sequence? – Paul T Davies Dec 23 '11 at 20:03
just a single beep. similar to coffee maker beep but less intense and only one beep. – Asdfg Dec 23 '11 at 20:05
Could be your dishwasher... Some models have an audible alert for when you need to change the water filter.
Have you checked couch cushions? Had a child watch fall into one of ours and it beeped on the hour. Other things to look out for old cell phones or pagers which are alerting that their battery needs to be charged.
beeping is coming from the basement. It looks to be sump pump battery is dying. – Asdfg Dec 27 '11 at 18:26
@Asdfg glad you found it! – ahsteele Dec 27 '11 at 20:09
protected by ChrisF Jan 17 '12 at 16:56
This question is protected to prevent "thanks!", "me too!", or spam answers by new users. To answer it, you must have earned at least 10 reputation on this site.
