When opening the rubbish chute, there is always a disgusting smell. Is there any way to remove it such that when I open to throw my rubbish, I will not smell it?
Have you tried throwing away more lemons and perfume? How about a big fan to pressurize the room with the chute or create a vacuum at the bottom? You could also try a clothes pin on your nose. – BMitch Dec 23 '11 at 12:09
up vote 3 down vote accepted
To some degree, your garbage chute is always going to smell a bit like garbage. There are however some things simple and complex you can do to reduce it.
First, you need to clean it and ensure that any stuck food/grime is dislodged. Give it a hose-down (pressure washer if you can) and then disinfect/deodourize it. If there is crap stuck in there, it doesn't matter what else you do, it will keep smelling.
Make sure that whatever you throw down it is in a sealed bag; do not throw loose scraps down.
If it doesn't already have one, a flap on the opening will help keep some of the smell down - usually you have to push you garbage through it and then it springs back closed.
If you can control it, empty the garbage bin at the bottom frequently so food does not sit down there rotting (and smelling for ages).
As a commenter mentioned, positive pressure in the room will keep the smell from leaking into the room. Condo's use this mainly for fire prevention but it also helps keep smells at bay (or in the originating condo at least). A fan alone will not create the pressure, you need to be bringing in outside air at a faster rate then it escapes so that there is always positive pressure.
Very comprehensive answer. I suspect that there is a crap stuck in there - will definitely use a fireman hose to settle this problem. – Larry Morries Dec 27 '11 at 3:23
Carefully splatter bleach all over the sides of chute. I used to have to do it for a 3 story apartment building.
  1. Clean it.
  2. Hold your breath.
  3. Use some air freshener.
  4. Deal with it (it is after all, a rubbish chute.)
+1 Nice one - hold my breath. – Larry Morries Dec 27 '11 at 3:25
You could set up some sort of fan / blower mechanism that creates negative pressure inside the trash chute. That way the smell only goes out.
I do agree that some sort of fan / blower will be helpful but then I will need to perform maintenance on the fan / blower - which kind of creating extra work for me since the trash chute might be smelly because of some neighbors who try their smelly rubbish without tying them into a plastic bag. – Larry Morries Dec 27 '11 at 3:25
protected by Community Apr 17 at 15:25
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
