Tell me more ×
My real question, after several hours spent removing the old faucet (progressing from tapping the basin wrench with a mallet, to an overnight soak in penetrating oil, to cutting it off with an air grinder) is "what idiot engineer uses a mild steel washer in a wet environment?" But it looks like they all do, or at least the ones who designed the new faucet do, so ...
On the assumption that I or someone else will someday want to change the faucet, what can I use to prevent the nut from freezing to either the washer or the faucet body? If I were working on a car, I'd use thread sealing compound. Does that make sense in this application? Or are there any professional tricks that aren't quite as messy?
1 Answer
Anti-Seize Lubricating Compound
Make sure it's waterproof
Pipe Dope
Make sure it's Anti-seize
I do not specifically recommend nor endorse either product, they are only used as examples.
I worried this would be the answer. +1, but I'm still hoping that someone else will come up with something less messy in the next couple of hours :-) – kdgregory Dec 22 '11 at 21:26
@kdgregory Messy? I think you're using it wrong. – Tester101 Dec 22 '11 at 21:31
