I recently walked my roof. There are some low spots, like little depressions. What causes this and should I be concerned? It seems that the plywood underneath is good but it seems like the underlayment has degraded. Is this normal?
Tell me more
Plywood generally doesn't sag permanently unless it's been wet for an extended period of time. Can you get into the attic to check for water stains around those areas? |
