I am thinking of getting back into stained glass. One of the projects I want to work on is to fix a stained glass window that has a section with a crack in it. I was given a couple soldering irons that have spent years in the basement and are rusty.
Can I use these irons? Is it safe? Are there quality concerns I should be aware of?
as long as they are not damp you will be ok. The life of these might be shortened because of heat element damage.. iuf any occured. You can always get a DIY on for a few bucks – ppumkin Nov 28 '11 at 13:26
up vote 5 down vote accepted
My guess would be that as long as the cords look OK, I'd clean them up a bit and give them a try. Burnish and tin the tips well. Just be ready to pull the plug if they start to overheat or something.
And use a sensitive plug in RCD. – Walker Nov 28 '11 at 12:44
Thanks. Can you provide me with advice for how to "burnish" and "tin" the tips and tell me what a "sensitive plug in RCD" is? – Roseaboveit Nov 29 '11 at 20:50
Burnishing is simply cleaning the tip with a very fine abrasive such as 440 or finer emery cloth. the idea is to remove all corrosion and smooth out any pits in the metal. Tinning is applying a heat transfering coat of solder to the tip. To do this, heat the clean tip, melt a bunch of solder on it and swipe it across a damp sponge. The tip should now appear bright silver and very smooth. If black spots still appear, burnish them off and re-tin. – shirlock homes Nov 30 '11 at 11:05
What is a RCD? I also have no idea what that term means. – shirlock homes Nov 30 '11 at 11:07
RCD is known as a GFCI in Canada/US – Steven Nov 30 '11 at 17:35
