Sign up ×
My Amana gas clothes dryer is not heating properly. The gas ignites when the dryer is first started, but after the gas turns off the igniter glows and then turns off, without relighting the gas.
Many websites I found said that this was typically due to bad coils. I removed the coils and tested the resistance across the terminals. The resistances match example values I found.
Could the coils still be defective, or is it more likely that the gas valve is bad?
This site says that the valves rarely fail and that the coils are typically the cause:… – M. Dudley Nov 26 '11 at 20:57
This could be an issue with the thermocouple. A thermocouple is used to sense whether the gas was ignited by the glow coil and is burning. If it isn't burning, and the thremocouple isn't heated up by the flame, the gas valve is shut off to prevent excess gas buildup.
Although this might not be the exact problem, it might lead you down the right path to find it.
May also be known as Flame Sensor or Flame detector. A Thermocouple, is just one type of flame sensor. See Flame detector – Tester101 Dec 6 '11 at 18:23
up vote 2 down vote accepted
The coils were defective. Bought replacements on Amazon and everything's back to normal!
Thanks for the update! – lqlarry Mar 5 '12 at 6:24
