I just purchased and installed a new Panasonic FV-10NLF1 inline exhaust fan. My house has copper wiring, but the wires on the fan appear to be aluminum (they are silver in color). I didn't think anything was made with aluminum wire anymore.
What special considerations do I need to take when connecting the copper house wiring to the fan wires?
I've come across steel wires as well. Usually when the wires are thin, and subject to physical forces. – Chris Cudmore Nov 24 '11 at 16:13
I would make sure your insurance covers this situation. Some insurance policies will not cover homes with aluminum wiring. The easiest solution is just finding out for a fact if it is aluminum wiring, and then returning it and getting something compatible. – Hemm Nov 26 '11 at 1:24
You can't buy new household electrical devices which use aluminum wire. It is either steel or tinned copper. – Brad Gilbert Nov 26 '11 at 4:46
up vote 5 down vote accepted
Sometimes with stranded wire, they will tin the ends with solder. I would guess this is the case here since you're right that aluminum is not usually used. I think the only reason they do this is to keep the ends from fraying and keep it neat.
You can check for sure by stripping new ends.
I have never seen stranded aluminum, or anything less than 12awg used (most house wire is 14awg copper, which is a bit smaller). You can see in this picture the aluminum is slightly bigger:
I would also be very surprised to see aluminum wire since it requires special wire nuts (co/alr rated) and an anti-oxidant paste (eg, Noalox) to connect.
If it's just tinned copper, you can twist and wire nut to a regular standed wire, just treat it like a normal copper wire.
+1, also aluminum wires can be stranded, but each component will be at least 2,5mm<sup>2</sup>, so that only happens for wires with cross-section of more than 25mm<sup>2</sup> - not something that one will find in a bathroom fan. – sharptooth Nov 25 '11 at 6:52
