Our house has a wood burning firplace that we want to convert to something else but we have no gas lines in the area. What are our options for heating benefits and esthetics?
All very nice and stylish.. Electric fire place! This will be the easiest way to replace your wood fire place. But the cons in most countries is that electric heating is very expensive. Pros are well.. clean and easy. Press a button and set the heat you want. Effects vary and they are not expensive. If you want to use gas, then you have some options. If you have a basement directly under the fire place you can make a safe place to store gas bottles and just put a supply line directly above to the gas fire place. Easy to to replace once every few months and lasts for a bit. If you have no basement then maybe if space permits a safe place somewhere outside on your wall- hidden away form first sight(but easy access to replace) and run some gas lines to the fire place. Last option is to keep the gas bottle somewhere in the same room in a safe,ventilated cupboard.. like some people use the a gas stove with a supply bottle right under it. This is the last option (maybe easiest) but safety is a big concern though. propane(gas) bottles or cylinders.
Propane tank
The main options would be:
That's probably going to depend on your reason for not wanting to keep a wood burning fireplace. But assuming that the chimney is good, you might also want to consider a wood pellet fireplace insert. |
