Tell me more ×
I just moved into my house and I am wondering if this is normal for a furnace.
So I have my furnace set to 68 degrees. The temperature on the thermostat says 66 degrees. The furnace is on, but does not appear to be blowing warm air (I guess I would describe the air as not warm, but not cold).
So then I turn the furnace up to 71, and the thermostat still at 66 degrees. The air coming out of the vents is warm.
I have not tried this long enough to see what happens as the thermostat approaches 71 degrees.
Is this normal? As the temperature on the thermostat approaches its setting does the temperature of the air coming out of the vents decrease?
Does your thermostat have a switch for the fan, and is it set to "on" or "auto"? – BMitch Nov 18 '11 at 3:44
It is set to auto. – Josh Pennington Nov 18 '11 at 9:34
Is your furnace a two-stage furnace? – The Evil Greebo Nov 18 '11 at 10:38
And in addition to Greebo's question, how long has the furnace been on when it's running cool and set to 68? In other words, is it just after the furnace cuts on, or are you giving it 2-3 minutes to see if it will get warm without adjusting the thermostat. – BMitch Nov 18 '11 at 11:23
Is there flame in the furnace ( you'll have to open the access panel to tell)? – Tester101 Nov 18 '11 at 12:05
show 5 more comments
1 Answer
up vote 5 down vote accepted
It sounds to me like you've got a two stage furnace.
Stage 1, low heat, just enough to maintain temperatures. Won't produce warm air, just warm enough air - much more efficient than running full burn.
Stage 2, high heat, for when it's actually cold. Produces WARM air intended to raise temps. Less efficient than stage 1, but gets the house warm. Stage 1 follows.
The alternative is a 1 stage furnace that's full on, full off, and thus must cycle on and off over and over again.
The other possibilities are that stage one isn't working, or that it's a single stage furnace wired to the second stage. – BMitch Nov 18 '11 at 13:36
I'm not familiar with the furnace but I would place a reasonable amount on a bet that says stage 2 can't ignite if stage 1 can't ignite, since it only makes sense that stage 2 would be more gas/burners in use than stage 1. – The Evil Greebo Nov 18 '11 at 15:52
I was thinking more of a mis-wired thermostat rather than a mechanical failure. That said, the most likely answer is yours, a properly functioning 2 stage. – BMitch Nov 18 '11 at 17:15
I had someone out to look at the furnace. It turns out it the flame sensor was bad. – Josh Pennington Jan 23 at 14:42
