I have a house with no wall heater, and would like to install one. What criteria should I use to help me determine the best place for the heater? Is it better, for instance, to be on an inside wall? Would it be better to have it beside the door of a room I want to get some of the heat, or on an adjacent wall, to "direct" the heat toward the door?
under a window.. mixes cold air with warm directly giving the best mixing ratio. – ppumkin Nov 17 '11 at 15:58
Why are you installing a new heater? Why a wall heater? What existing heat sources are there? – gregmac Nov 17 '11 at 18:21
There was a wall heater originally, but the owner didn't like its location, removed it, filled in with drywall and painted, and used only space heaters. – Carl Manaster Nov 17 '11 at 18:30
up vote 2 down vote accepted
Most HVAC's are designed with vents near areas or low insulation or drafts, which are typically windows and doors on exterior walls. I'd suggest the same should be done for any space heater, baseboard, or in your case, a wall heater. The reason is to equalize the temperature in the room and counter-balance any drafts.
That said, a wall heater will have different requirements from an HVAC vent, the main one being that you only have a single heater rather than lots of vents. You have to consider the power/fuel source and how you'll run the line to your selected wall. Be sure place it where combustible materials won't be placed near the heater (the specs on the heater will tell you how much clearance it needs).
One last consideration is to maximize the space that can receive heat, and in particular the spaces that you plan on using the most. So if you place it in a room and close the door, no other rooms will be heated, but that room will be heated really well. If you place it in a hallway, the whole home will get some heat, but each room will only get a little of that heat and only when their doors are left open.
