Tell me more ×
I've been researching soundproof underlayments for floors, but the selection seems to be very paltry. It appears that you're pretty much stuck with mass-loaded vinyl (MLV), QuietWood, and a few other sheet-type materials. The bad part is that these are not as effective as materials used for soundproofing walls and are certainly no good at blocking lower frequencies, so I came across an idea: What about MLV on my subfloor, followed by Green Glue (GG) then cement backer board (BB)?
I think this would be a very effective solution. Putting the MLV down first would put a protective layer over the subfloor so I don't get it all gooey with GG. Instead, the GG would go between the MVL and BB. After I seal all the BB seams with accoustical caulk and tape, I would then lay my carpet over that.
If BB is too over-the-top, what if I replaced that with simple 1/4" plywood?
google.co.uk/… leads to some pages the descibe how floor have to be sound proved in new UK flats – Walker Nov 16 '11 at 13:32
up vote 3 down vote accepted
Answering my own question here with an email response from a Green Glue associate. In response to me basically asking him the exact same thing as in my original question:
This application will certainly work. We would recommend using the heaviest & thickest material that you can...1/4 plywood is going to be a bit too light & thin. If height is what prevents you from using 1/2" plywood or greater, consider using 1/4" cement board (Hard Backer) instead of the plywood. The cement board is heavier and stiffer than plywood and will offer better performance.
What I am going to do first is lay down 2-lb MLV, acoustically caulk it, and tape it. I will then turn up my subwoofer, run down to my garage directly beneath it, and, if the MLV doesn't appear to be performing to my expectations, I will start my plans to put down cement board with Green Glue in between.
Note that the cement board is not for soundproofing in and of itself, but to provide a second firm surface to allow the GG to perform at its best.
I'll post details here in a few weeks to report my progress and also post pics.
Interesting. I guess it's time for me to read up on what this GG does. Thanks for following up. – BMitch Nov 18 '11 at 2:41
Any report on how this worked? I'm wondering if I should do the same thing. How did you contact Green Glue? Their e-mail form on the web site is broken. – Patrick Szalapski Aug 14 '12 at 17:27
The reason the floor materials aren't as effective is because this problem is best solved with an air-gap and a flexible connection spanning that air-gap. But you have a hard time supporting a floor with that air-gap. Therefore, solving this problem via the ceiling below this floor is better, using resilient or sound attenuation channel there.
That said, on your floor, carpeting over Homasote, QuietWood, or some other material will be as good as you'll get on the floor. Since I don't have experience with MLV or GG, I'll defer to others on that. However, the cement backer board seems like the weak link here since that will transmit sound rather than absorb it.
Even if I could do the ceiling below (my garage is below my room), it wouldn't help because there would be too much flankery as the sound goes through the floor and diagonally to my neighbor's condo. The only true way is to contain the sound within the room. The reason I suggested BB is because it is a heavy, firm surface that will keep foot falls from squishing the GG around through the carpet and padding. What draws you to the conclusion that BB would help transmit sound? – oscilatingcretin Nov 16 '11 at 13:41
@oscilatingcretin BB doesn't compress. To stop sound, you want something that compresses itself rather than propagating that compression to the next layer. – BMitch Nov 16 '11 at 13:49
Having worked with and cut BB, that actually makes sense. Since GG and MLV are made for soundproofing, I should be able to get away with thin plywood. After all, all I need is a firm surface to help sandwich the GG between the MLV. – oscilatingcretin Nov 16 '11 at 14:14
