With a rather large living room in my 1bd appartment, I'm building a semi-permanent partition to split off a second smaller bedroom. The partition will be a standard framed wall and put in place without modifying existing structures (just nailed to the floor, sides, and ceiling) in order to avoid losing my deposit. Basically a more solid version of a privacy curtain.
I understand that the small studs at the top of the door opening are to take over some of the loadbearing that is lost when you cut out a stud to make the opening. Is it acceptable to do away with this for the "decorative" structure I'm building? E.g. just a Master/jack stud with a head plate?
