I am living in the basement level of a rental unit with forced air heat. There are 9 heating vents and one cold air return, all of which are in the ceiling. The air isn't mixing very well resulting in a hot ceiling and cold floor. I would like to hack together a cheap cold air return that we can lower down to the floor. I suspect it will dramatically increase the comfort in our apartment.
Can you recommend a cheap non-permanent solution? I'm imagining a plastic flexible pipe with a standard attachment to a heating duct.
