Background: a large steel door at our office was recently painted with an oil-based paint, and we spent the day suffering through the fumes that permeated practically every space in the building.
What are the advantages of using oil-based paint over a zero-VOC latex enamel? Does it key better to steel (the door was primed; I'm not sure with what)? Is it more durable? What other advantages does it have over other options?
They should have removed the door, and painted it in an unoccupied area. – Tester101 Nov 9 '11 at 18:28
Is this a question or just a rant? – The Evil Greebo Nov 9 '11 at 18:44
Well, it's kind of both. I honestly didn't know why latex wouldn't be acceptable, but the tone of the post was definitely influenced by the headache induced by the solvent fumes. Anyway, I have my answer; latex won't stick to metal properly, AND the oil enamel will be more durable. Wish I could give them both the check. – KeithS Nov 9 '11 at 19:49
@KeithS I removed the rant portion of the question to try to save it (it's got a few close votes right now). If you disagree, feel free to roll back my change. – BMitch Nov 10 '11 at 14:29
up vote 21 down vote accepted
Enamel paints hold better, are MUCH harder than latex, and will stand up to a lot more abuse. You can also use harsher cleaning methods on them.
Latex paints won't bond properly to metal, it will flake, peel, and bubble off.
Understand that I only didn't give you the check because you already have 11k rep; gotta support the newer guys who also know stuff. :) – KeithS Nov 9 '11 at 19:50
Now ain't that the wrong reason :/ – Konerak Dec 2 '11 at 18:28
Social justice has made its way to stackexchange... – RQDQ Feb 9 '12 at 21:07
